Old 06-10-2013, 11:12 PM   #46 (permalink)
niky
Pretty sure a tech inspection is mandatory.
Note... if you have energy harvesting dampers, they're not creating free energy... they're recouping energy lost to movement. If the car is bouncing, it's not going to glide as far.
As for steering, it'd be pretty obvious if someone were to start weaving back and forth to pick up speed. And the pogoing motion (you need vertical movement) should be obvious.
