Old 06-11-2013, 01:43 AM   #12 (permalink)
campisi
Chief Cook & Bottlewasher
Xterra - '13 Nissan Xterra Pro-4X
90 day: 18.63 mpg (US)
Originally Posted by Diesel_Dave View Post
I always figured it was just because "non-critical" electrical draws are shut off during cranking to ensure the maximum allowable energy is left available to get the engine started. If you can't get the engine started, the radio doesn't matter.
My Subaru does this (radio shutoff when cranking the engine) and I always figured it was for the reason Diesel_Dave posted above. Interesting that your circuit worked. I'm annoyed by the 3-5 seconds it takes for my Subaru (Clarion) radio to re-boot after an engine re-start but not annoyed enough, yet, to try a fix. Maybe later. Good work.
Oh, meant to mention that maybe you'd want a current limiting resistor between D2 and C1 to limit in-rush current when you first charge C1 but, heck, if it works and doesn't blow Fuse F1 then ... far out!
