Old 06-11-2013, 11:17 AM   #11 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
You might need to make this mod switchable from the driver's seat.
At least on Hondas, I believe right after start the ECM commands full open then full closed to the valve and sets whatever the wiper pot reads as full open/closed values... a sort of recalibration each time its started. If yours does something similar, you might need to splice in a switch to your resistor circuit so you can turn it on after starting.
The Following User Says Thank You to samwichse For This Useful Post:
t vago (06-11-2013)
