Old 06-12-2013, 01:47 PM   #15 (permalink)
Xist
Originally Posted by jamesqf View Post
And you're asking this on an ecomodding site? Why on Earth wouldn't you turn off your computer (or anything else) when you're not using it?
As for the cookie cleaning idea, the problem is distinguishing useful cookies from the ad ones.
Honestly, most things that I do, I do on the computer, and I usually have Classical music playing at all times. I do believe that I have an actual radio somewhere, but I would rather not use a radio in addition to a computer, although I probably should put the computer to sleep and turn on the radio.
I do not think that actually has an "off" setting...
When I am not using my computer, I put it to sleep, or if it will be a while, in hibernate mode.
I think that I irritate my roommates by turning off unused lights. There is actually an increasing amount of tape over the porch light switch, so I loosened the bulb.
I also have box fans running at all times, but I tend to sweat even with them on, and I usually need to sleep on top of my bedding, which does not improve my sleep at all.
