Originally Posted by aerohead
Vortex generators were designed to allow flow reattachment at steep angles,onto a trailing structure.
Truck vans have nothing behind them to reattach to.
They don't need that if they can
make it quite literally
out of thin air with energised air.
Keeping the tailgate closed also helped as it created a bubble of air in the bed - where physically there's nothing there (but air).
Rear spoilers on a trunk that end up on the template also reduce FC, despite the sharp drop on the rear window.
Simple, flat end-plates on sticks reduce FC when the plates are sized to what a full boattail would be like at that distance.
So apparently, you don't necessarily need full-featured, physical hardware right up to the tail to better streamline a vehicle.
You likely won't get the maximum benefit out of them, but you also don't get the various inconveniences of a physical boattail.
If these vortices can enclose a boattail-bubble of air, you've boattailed the truck with ... nothing but air.
