I had a similar experience as duncan when testing my car with a smaller battery pack than normal. It turned out to be the DC to DC converter, which would cut out when the voltage sagged below 75 volts, causing the controller to lose power, usually when the accelerator pedal was released and pressed again.
Adding another battery to the pack solved that.
