Well, back to real work soon.
Here was today's list with notes on what I need/ haven't done.
Remaining VW
Install ecu. DONE
Air compressor mount.
wire DWA
Swap clusters
Hood switch to CCM
Lift pump wiring
Trailer wiring
Install lift pump DONE
Swap out pre-lube pump (need pump to arrive)
Install ADI solenoid (must locate spare hose first) DONE
Wire ADI just need power now
plug in remaining engine connectors. ERR, SO FRUSTRATING
Plumb vacuum hoses / valvesERR, SO FRUSTRATING
Install coolant orb bottom hose (need hose CLAMPS)
Install coolant (need last hose)
Check heater hose length
Install power steering suction line (need line)
Install power steering fluid (need suction hose installed)
Install AC compressor (waiting until dead last)
Instal front carrier/ lights/ bumper has to be after A/C
Install clutch line (need clip)
Bleed clutch (need line installed)
Bolt in rear of drivers side control arm (need nut)
Bolt in front of dog bone (need bolts)
Mount and balance tires
Install fender liners
Clutch line quick clip needed
Ebrake cable rear trailing arm clip needed
Install/ wire headlight relays for auto headlights need to run wires in to car.
Install relay/ wire for pre-lube pump
Install fuel door DONE
Install fuel cap DONE
Add fuel
E-brake cable FRUSTRATING
E brake clip temporarily solved, need oem clip
Abs sensors DONE
Torque rear suspension
Install last exhaust hanger DONE
Secure vac. Pump near rack DONE
Install battery / battery box (need to complete wiring)
Install air box (need to install battery)
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
