What is the best way to clutch bump? Should you aim to do it at around 1000 rpm, ie. around idle speed, and as smoothly as possible? There's obviously more clutch wear with a slow clutch release. I just tried a bump for the first time, around 1500 rpm, and it was a bit jerkier than I was happy with.
