Old 06-20-2013, 06:18 PM   #3 (permalink)
IamIan
IamIan's Avatar
Originally Posted by sheepdog 44 View Post
Is this just a scangauge type device, or is it MIMA (manual integrated motor control), or is it both?
Can this be used on a CVT? And if so is can it disable assist and regen. Can i manually set the SOC?
IMAC&C is a MIMA like device.
Turn On or Off Assist at will ( while retaining BCM safeties )
Turn on or Off Regen at will ( While retaining BCM safeties )
OBDIIC&C is a scangauge like device ... but with options specifically for the Gen1 Insight no other OBDII reader on the market has.... this like manually changing the IMA battery SoC ... etc... but on it's own it is not a MIMA like device.
The two are not the same thing ... they can be used together , or separately ... and if built up from the base as one unit then they are one unit ... but they don't have to be together.
Yes they can work on the CVT Gen1 Insight.
