Old 06-23-2013, 06:49 AM   #15 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Originally Posted by jeff88 View Post
I just got a fill-up today, but I forgot to hit the up button to reset it. Dratz! So at my next fill up sometime next week, I will add in the amount of fuel used (pumped) into the 'calibrate mpg/fuel' menu? Or should I wait until the fill-up after that, when I reset the UG properly?
On my car the gauge recognizes the fill-up as can be see by the distance to empty resetting. Which reset are you referring to, the trip gauges or are you required to manually enter the fill-up? Even if manually entered fill-up is required, on the next tank just add the gallons from the from both fills and enter.
