Thread: my custom CAWAI
Old 06-23-2013, 05:02 PM   #11 (permalink)
jmmbmd2013ph
Dr. J
jmmbmd2013ph's Avatar
Originally Posted by nemo View Post
I the early 70's my father did some fleet testing of GM HEI distributors. One of the thing he told me was that after 60K miles they would change the plugs and performance would go down, it seemed the new plugs were not gaped wide enough to take advantage of the output. As part of the changeover to an electric distributor were you require to change the plug type or gap?
hello again! nope, I did not change my sparkplugs, I still retained my stock NGK Sparkplugs for my Toyota even after I changed my distributor, I also got an 8mm Mallory high tension wires for it though. Was there any specific measurement for the gaps in the sparkplugs when using an electronic distributor? thanks!
