Old 06-24-2013, 06:06 PM   #11 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I would invest in jumper cables before a PV charger. When your battery is dead, you want to start it immediately, not 8 hours from now assuming it dies during the day in the sun. That said, using one to maintain the battery of a vehicle that sits is a good use.
If your battery is still weak despite PV "maintaining" it, then you need a higher output PV. The battery will eventually fail from discharging so low.
