Thread: 19MPG to 30MPG+
Old 06-24-2013, 11:00 PM   #14 (permalink)
oil pan 4
Originally Posted by hawk2100n View Post
Looks like you solved your problem with the O2 sensors however if you continue to run into problems, do a search for the spark plug non fouler - O2 sensor trick. Very simple to do. They add a some standoff to the oxygen sensor by pulling it out of the exhaust flow and make the car think the cat is working. My car had the cat removed by a previous owner and that was able to get the CEL to stay off for 40k miles.
I don't like mods like that to be at all visible from the outside.
Usually what I do is cut a little peice of sheet metal and bend it into a cylinder and slip it around oxygen sensor to block most of the exhaust flow going into the sensor.
