Old 06-28-2013, 08:46 AM   #104 (permalink)
More air less fuel
The Seinfeld episode with Jimmie and his third person persona cracked me up, so I thought that I would have fun with it. I see that it didn't work....
Anyway, the car is mine, I designed and built it back in 1985-1987 and it's only purpose was to get great fuel mileage. It was originally powered by a 1980 VW diesel that I added a Rajay turbo to and ran about 9 psi of boost. It got about 65mpg at 65 mph back then. Now it has a 1.9 TDI AFN motor in it and gets 74 mpg at 60 mph. The tune that was in it was more performance oriented and dumped a lot of fuel during hard acceleration. Fun, but not as efficient. The newest tune is much cleaner, albeit not as fast. Engineering tradeoffs....
I made the body out of poly isocyanate foam board and covered it in glass and epoxy resin. The frame is a space frame made from 316l stainless steel. I know, what was he thinking! (I hate rust!) Front suspension is modeled after the Ford Mustang II/ Pinto set up, just copied it out of stainless.
The rear suspension is made up of the strut and brake/spindles from a 1972 Datsun 240Z. Front and rear have coil-overs. The engine/transaxle is in the rear as a mid engine layout. DLC PP520 injectors, VNT-17 turbo, water cooled intercooler, fabricated intake, 2.5 exhaust with Magnaflow muffler, tune,
thinnest head gasket, port clean up, unshrouded valves, air/oil separator, and I forget what else!
The windshield is from a McLaren, the door frames, hinges, and latches are from a 1967 Corvette, taillights are 1982 aftermarket Corvette, side markers are Ford truck, front directional are 1972 Camaro.
I designed this car on paper after being hit broad side on my motorcycle at an intersection by a drunk chic. Cops never figured that part out....my friend did.
I had plenty of time to do this as I was laying in a bed for a good part of a year with a couple casts on.
Hope that helps.
The Following 55 Users Say Thank You to More air less fuel For This Useful Post:
2003protege (06-29-2013), aardvarcus (07-16-2013), aerohead (06-29-2013), AndrzejM (07-02-2013), AntiochOG (06-28-2013), brucepick (07-13-2013), btracing (07-22-2013), Cd (06-29-2013), ChazInMT (06-28-2013), christofoo (04-30-2014), COcyclist (12-08-2014), Daox (06-28-2013), darcane (06-28-2013), easythereturbo (09-03-2024), Ecky (03-16-2014), Econoguru (03-19-2014), ECONORAM (07-11-2013), elhigh (07-01-2013), Fat Charlie (06-28-2013), Insight for life (06-28-2013), JRMichler (06-29-2013), lowglider (06-30-2013), mcrews (06-28-2013), MekLogan (07-17-2013), MetroMPG (06-28-2013), mikeyjd (06-28-2013), NachtRitter (06-28-2013), NeilBlanchard (06-28-2013), nemo (06-28-2013), Nevyn (06-28-2013), oil pan 4 (06-28-2013), Pawtuckett (06-28-2013), pgfpro (06-28-2013), Phantom (08-01-2013), Piwoslaw (07-21-2013), pletby (08-07-2013), RealZ28 (07-01-2013), RedDevil (06-28-2013), redneck (06-28-2013), Rishar (05-17-2014), rjacob (06-28-2013), ron (06-28-2013), Ryland (06-29-2013), seifrob (07-07-2013), sheepdog 44 (06-28-2013), sloan (06-28-2013), Slow_s10 (07-01-2013), solarguy (06-28-2013), some_other_dave (06-28-2013), SpindlyJim (06-29-2013), Sven7 (07-21-2013), UltArc (06-28-2013), whatmaycome14 (12-21-2013), wickedwagens (03-27-2014), Xist (06-28-2013)
