Old 06-28-2013, 09:52 AM   #14 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by slowmover View Post
DD, are you using the MB-spec DELO 50 in that G56 trans?
No. I know Dodge specifies the tranny fluid has to meet ATF +4 spec. I know there's been some chatter on CumminsForum and elsewhere as to whether it's actually better to use the MB-spec, because that's recommended by Mecedes in Europe for the same tranny (if I recall correctly). While it seems odd to me that Dodge recommends an auto tranny fluid in their manual, I decided to stick with something that meets the ATF +4 spec. I use Castrol Transmax ATF+4, as it had the best viscousity and wear characteristics of any ATF+4 fluid that has published specs.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 3 Users Say Thank You to Diesel_Dave For This Useful Post:
101Volts (08-14-2013), ECONORAM (07-03-2013), slowmover (06-29-2013)
