Old 06-28-2013, 04:27 PM   #32 (permalink)
TurnNBurn
Originally Posted by P-hack View Post
Needs more homework if the me0913 will work with the bldc controller I just linked to (bldc is the square wave version of PMAC, so they do often work just fine, not always).
Which spec are you referring to?
*3-Phase Permanent Magnet Brushless Motor
*24 - 96 Volts
*Efficiency of 92%
*12 KW (180 amps DC) continuous @ 96 Volts
*23 KW for 1 minute (600 amps DC) Peak @ 96 Volts
*Peak Stall Torque of 90 Nm (66 ft)
*Designed for long life. No brush maintenance.
*8" OD, 7.17" long (w/o shaft)
*7/8"x 1-5/8", 3/16" key shaft
*35 Lbs
And when I was looking at motors, I specifically browsed DC versus AC categories. But I've been researching this project for a while and settled on the motor first and then found what controllers would work with it. But I guess the phases were just overlooked. And I guess this link confirms it: http://www.thunderstruck-ev.com/moto...ity-chart.html
But I'll just sell the motor and go with the ME1003. I'm already getting a box to pack it up to get it sold. Man, this thing is heavy.
