Originally Posted by bschloop
You mention that the kit would be for honda shaft drives, does that mean it would fit a goldwing swingarm?
The adapter shaft I have fits the splines of the Goldwing, I've only done test fits on other peoples Goldwings as I don't own any Goldwings my self, so it would be more work to make the adapter plates that bolt to the Goldwing frame, but that could be done with a drill press in a home shop, but the splined shaft that connects the drive shaft to the golf cart motor is a hard part to make in the home shop.
