Old 06-28-2013, 10:34 PM   #1 (permalink)
Frank Lee
Gas pump meter creep
Report: Many Gas Pumps Overcharge Customers
Here's an argument against using the same pump every time:
Much ado about nothing, having calibrated many gas pump meters here is the scoop. The meters are set to zero if they can be( state regulated). In some states plus 1 or minus 1 is acceptable. After a pump is calibrated a state seal is attached so that it can`t be tampered with. A meter that won`t calibtate to zero or plus/minus 1 is usually reported and changed. lets say you go to a station that has 6 pumps. Each pump as 2 meters one on each side. Of those 12 meters a few many calibtare to plus or minus. My advice is don`t fill up on the same pump every time. You may or may not be getting the best deal. If you remove the nozzle and set the pump and it creeps up there is a problem somewhere else in the pump. Report it to the manager.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Cd (06-29-2013), pgfpro (06-29-2013)
