Old 06-29-2013, 09:07 AM   #40 (permalink)
Weisheimer
Mark Weisheimer
I saw in another forum that you are in London, Ont.
I suspect shipping would run about $20 each way if you use ground.
It would probably be about 2 days transit, but I don't know about customs holding time.
You could check FedEx/UPS and see what they have to say about transit times.
Tell them that you are shipping it to a commercial address Columbus, Ohio 43215 for warranty repair.
It's about a 5 hour drive...I have relatives scattered between Sarnia and London so have driven it many times.
But, fixing it there yourself is certainly more self satisfying.
If your micro-controller is soldered in, I would cut the legs at the body and then de-solder the remaining legs.
The PS boards soak up a lot of heat, so practice and a powerful temperature controlled soldering station are helpful.
I use a Weller temp controlled soldering station for most work, but also have this very old Western Electric soldering iron that is massive.
I call it "the persuader"...
