Old 06-30-2013, 12:30 AM   #68 (permalink)
GreenHornet
GreenHornet's Avatar
I want to take a moment and dive more into the gearing and its importance as it pertains to small tractor diesels such as the 2 cylinder Yanmar. Often times we see people swapping these engines into small cars thinking that they will get incredible fuel mileage. Few do and most don't and a big part of the reason is the gearing. Transmissions are mated to engines to compliment them and most of the time its a compromise even for the stock engine whether more acceleration or fuel economy was the primary focus. Rarely you get a stock tranny that gives you both performance and economy. So we are usually stuck with what we got and have to live with the powers to be. The trend recently has been to offer more gears in a way to improve fuel economy without sacrificing acceleration. For many cars this strategy has helped to a point but with more gears weight starts to play a factor and you get to the point of diminishing returns.
In order for a small 13.4hp Yanmar engine or any tractor engine for that matter to have good acceleration and great fuel economy you have to purpose build a manual transmission. The transmission needs to be relatively light, efficient, and have good gear swapping ability and options. This way we can have both acceleration and fuel economy. Now obviously this is not the only piece of the puzzle as weight and aerodynamics also play a huge factor but like the old saying goes you are only as strong as your weakest link. The saying definitely holds true when it comes to optimized gearing.
Another trend for car manufacturers in today's sub compact car market to use smaller turbo engines and couple this with lower 1-4 gearing and then give it 1 or 2 overdrive gears for increased fuel economy. A good example of this is the Honda Insight Gen 1 and the Chevy Eco Cruze. However the Cruze being a 3,000lb plus car actually utilized 3 over drive gears in its transmission to help give it its 50 plus freeway cruise fuel economy. Pretty good for a modern 5 seat non hybrid car that weighs over 3,000lbs.
So the candidates currently for the Tigon are the T5 which I proposed earlier and a T56 6 speed. Further investigation needs to be done to determine if a T56 will even fit into a small car such as the GT6. I have my doubts to be honest but the T56 would give some interesting options for the Tigon ecomodder.
For example a typical T56 gearing with a 3.63 rear diff may look like this:
1st= 2.97/10.78 2nd= 2.07/7.51 3rd= 1.43/5.19 4th= 1.00/3.63 5th= .84/3.04 6th= .56/2.03 FDR= 3.63
also can be like this:
1st= 2.66/9.65 2nd= 1.78/6.46 3rd= 1.30/4.71 4th= 1.00/3.63 5th= .74/2.68 6th= .50/1.81 FDR= 3.63
The dry weight of these units are 115 and 108 respectively compared to 75lbs for the T5 regardless of configuration. However you get 2 overdrives and a taller one at that for 6th gear. However you have far less options for gears 1-3 which is very important for a small tractor engine being used in a car application. So the rear differential would need to be bumped up to the 3.63 for adequate acceleration most likely. However by adding the electric hybrid option and turbocharging you might be able to comfortably get away with the taller 6 speed. From the stock Yanmar perspective the T5 gives you the best trade off between acceleration and economy at a cost effective price point. So if I was going to only keep it stock diesel than the T5 would be the best candidate in my opinion. If the length of the T56 is not prohibitive than in a turbo and hybrid design the T56 would give some interesting potential with better fuel economy potential despite the added size and weight.
T5 gearing specs = TTC: TREMEC Transmissions
T56 gearing specs = TTC: TREMEC Transmissions
GH..
