Old 07-01-2013, 12:22 AM   #121 (permalink)
Occasionally6
Originally Posted by ctgottapee View Post
Producing a car with tandem seating strays too far from the basic car nomenclature.
Once again, that's the idea.
The offset seating is a great compromise, and most single travelers take advantage of the spare seat as storage; much less convenient in a tandem array.
With the provision of rear seat passenger leg room either side of a driver, there's space for storage.
Tandem requires height
Why?
Tandem sacrifices drive-ability, especially with a passenger as any motorcyclist will know.
How? Particularly in a very light vehicle, the weight distribution is less affected than it is with side by side seating.
If the wheels have to be wide, might as well put the seats wide anyhow.
Except that there are advantages in putting the driver close to the centreline of the car, regardless of where the wheels are.
Many others have tried to produce a tandem or single seat vehicle and have all failed so clearly there is not a viable market. In the end its basically just a covered motorcycle...
Yes, there are marketing reasons why a tandem seat arrangement might be seen as less desirable. Very large (fat) people won't fit in the passenger seat, and women won't like not being able to wear a skirt with dignity intact but they're not engineering reasons.
The Light Car Company Rocket was successful, at least for what it is.
Where would the battery pack be in a tandem seat design? To keep the height the same as the XL1, a tandem design would need to be quite long. The side taper would have to be reduced because you still have to fit the wheels and the passenger and the drivetrain.
Take another look at the original "One-Liter" prototype. It's not particularly tall nor long, has low aerodynamic drag and does have a battery in there (somewhere).
Another "compromise" of tandem seating is that the people can't see the other person's face.
Valid criticism. Is it any worse than offset side by side seating though?
