All very good suggestions guys, I appreciate your help a lot.
Roof rack and step bars have been removed.
Grill block I have considered, but it does get pretty warm here and the explorer usually comes to operating temperature very quickly. Maybe if I get a scan gauge to monitor the rad temp, I'll go ahead with this one.
Scan gauge, by the way, it's interesting that you said that one of those could get me to my target Lazarus. Does the scangauge actually alter the ECU for mpg? Or are you just talking about monitoring my driving habits?
Removing the rear seat is unfortunately not an option because I sometimes have three passengers. Removing the transfer case and converting to 2wd is also not an option because of six foot snow drifts in the winter (stupid canada). Can't remove hitches, bumpers, etc. because this is essentially a work vehicle and needs to be prepared to tow.
Sidewall pressure for my tires is 40lbs so I will add another 5lbs to them. Skinny/LRR tires would require new rims ($$$) and decrease the GVWR payload.
The computer on this truck is quite *****y and there is already a valve tick so I don't want to play around with timing. Overhauling cam/pistons is definitely out of budget. The air box however does pull in warm air.
The reason why I need the truck is because I deliver building materials to contractors. This is why towing and payload capacity need to remain unchanged. I don't have a bike but for personal trips we use the wife's 1.5L hyundai accent which gets 35 mpg in the city.
