Old 07-02-2013, 03:44 PM   #62 (permalink)
TurnNBurn
Originally Posted by P-hack View Post
do you know how much force your bike needs at various speeds? An interesting thing to consider is how fast it can go on 11.5kw as that is the continuous rating of the motor (regardless of the voltage applied). Can be determined by a bathroom scale weighing wheels and rider, and high and low speed coastdown tests.
This page lists 315lb/in at 2800rpm, 200 amps continuous (72v system). 72 volts can create about 26kwh @450 amps which is close to the peak rating anyway...
Mars ET-S Permenant Magnet Motor
before you buy more stuff, like %33 more batteries than you need...
So once you know your max continuous speed for 11.5kwh, you can choose appropriate gearing to hit 2800 motor rpm, and hope you have enough torque at max kwh to get you there satisfactorily (or do more maths, F=MA, or A=F/M plus resistance fudge).
Once the bike is together and working with the basics (batteries, motor, controller, etc...) I was going to try and refine it to get what I want out of it over the course of the next year. Gear ratios, reducing weight, etc... were all things I was going to do once I get it registered and drive it around for a while. To start I'm shooting for 35-45 MPH and then work my way up from there.
