Old 07-02-2013, 04:30 PM   #63 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
k, are you starting at 72 volts? Or do I need to keep typing? It is more than enough for continuous use and is sufficient to burn out the motor in under a minute, plus it is a standard voltage for chargers, and your controller is designed for it.
Sprockets on the other hand are fairly cheap to experiment with, though still worth making an initial educated guess.
