Old 07-02-2013, 04:32 PM   #64 (permalink)
TurnNBurn
Originally Posted by P-hack View Post
k, are you starting at 72 volts? Or do I need to keep typing? It is more than enough for continuous use and is sufficient to burn out the motor in under a minute, plus it is a standard voltage for chargers, and your controller is designed for it.
Sprockets on the other hand are fairly cheap to experiment with, though still worth making an initial educated guess.
I was going to start at 72v for everything, but I didn't plan on going full speed ahead at 72v until I sorted everything out at 36v. I don't want to kill myself on the first run.
