Old 07-02-2013, 06:15 PM   #40 (permalink)
user removed
My latest bike is a GS500E 1994 model with just over 10k miles. Second tank was 62.45 MPG. I'm sure it has not run right in a while since one of the air slide springs was broen in half and wound up in itself. Some fuel lines, front fork seals, brake and clutch levers and bar end weights. I have $1500 in it now and it looks very nice, probably garage kept from day one.
I like the center stand expecially for chain adjustments and chain lubrication. I like the visibility of the black, silver, red and white color combination, great for visibility. I like the DOHC but two valves per cylinder, cast alloy wheels, tubless tires, and CDI ignition. Transmission and final drive gearing are great also.
regards
Mech
