Old 07-02-2013, 07:59 PM   #4 (permalink)
RustyLugNut
If your car has digital injectors . . .
Originally Posted by jeff88 View Post
I read through that thread. I would like to use an Arduino, which I am planning on installing soon anyway. My Arduino project will already include tapping into the VSS, so just the flow meter reading and a way to measure time would be necessary. Any ideas on what kind of flow meter to get and how to attach it, without impeding the the flow of fuel? Also, would a meter right after the fuel pump suffice, or should I attach it somewhere else like the injectors for a more accurate reading (e.g. to account for things like fuel return, which I do not know if my car has)?
Thanks!
. . . just use the arduino to tally the total time the injectors are open. You can then equate this to a volume flow of fuel for a unit time - assuming constant rail pressure.
