Old 07-02-2013, 10:43 PM   #19 (permalink)
RustyLugNut
There are many issues to deal with.
Originally Posted by jeff88 View Post
So here is a basic start to my idea. Needless to say, in no way is it anywhere near complete, nor perfected, obviously.
Here is the basic idea:
  1. An oxygen concentrator draws air from behind the radiator (or wherever you want)
  2. OC will compress the air and create a near 100% oxygen content which will be directly injected into the cylinder
  3. At the same time, fuel will be directly injected
  4. During the compression stroke, the pressure from the piston will force the oxy/gas to ignite
  5. Exhaust (which I think will be hotter than a standard engine) will run a turbo
  6. Turbo runs a generator
  7. Power from generator supplies battery
  8. Battery powers OC
Some issues:
  • I doubt the turbo will be able to supply all the power to the concentrator, but hopefully it can and maybe a little bit more.
  • How to "vent" the exhaust from the cylinder, other than a standard exhaust valve?
  • Is water injection still necessary?
The main hindrance will be the rate of production of your oxygen concentrator. Medical devices that use pressure swing adsorption can produce up to 10 L per minute of near pure oxygen. However, they are quite large in physical size and will require wall power levels to run ( hundreds of watts ). This small amount of oxygen could run a small single piston engine but that engine will not have the exhaust energy to power a substantial turbo
