Old 07-03-2013, 04:22 PM   #77 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Originally Posted by ConnClark View Post
electric cars are about as efficient as gasoline cars, but coal is cheaper than gasoline.
I'm having trouble following this... The charging efficiency of lithium is like 99%. Solar cost me around $3500 for 5.6kW. There were a few hundred extra dollars for the frame. The inverter can power about 16 houses (well, it's good to around 160kw) and is like 99% efficient at peak power. The MPPT charge controller will also do around 160kW. It's over 99% efficient at max power. Both of those cost less than $1500 to make each. That's like $100/house. The multicrystaline cells have gotten so much cheaper. You can regularly buy the panels for around $0.60/watt. Assuming a 3 phase motor, you can get over 90% efficiency. How do you get to the equal efficiencies?
kits and boards
