Old 07-08-2013, 05:09 AM   #10 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by JeffD View Post
Should have known I was in for it . The idea was to add a bit of turbulence to the BL to get past the wheel well without flow separation.
The wheel well is a very high turbulence area - bad aerodynamics and a spinning wheel ...
VGs will have a tough time fighting all that existing turbulence.
It wouldn't be easy to design and position VGs to blanket the wheel well.
If it's possible at all ...
Maybe it'd work better if I was going as fast as a jet instead of 55?
On aircraft, VGs are used to keep the airflow on the wing / fuselage.
In front of a wheel arch ... there's nothing much to keep the air onto.
Did you decide on the truck's color to match the tape ?
That's dedication
