Originally Posted by Xist
The cigarette\charger outlet does not work, nor does the OBD-II connector, so I cannot use my Ultragauge, and things would be complicated if I had a CEL.
Check your fuses
The cig outlet has a fuse either in the cab or possibly under the hood
The OBD-II may be the same way
