is the roxul the 2 inch insulation board?
if it is it would be nice and ridged.
If the door panels have an angle at the top and bottom you will end up with an air gap unless you can flex the product and pop it into place.
I have installed rockwool sound control batts before and they will make you itch just as bad as fiberglass.
