Old 07-10-2013, 12:19 AM   #20 (permalink)
Xist
Originally Posted by lordherald View Post
is the roxul the 2 inch insulation board?
if it is it would be nice and ridged.
If the door panels have an angle at the top and bottom you will end up with an air gap unless you can flex the product and pop it into place.[Image]
I have installed rockwool sound control batts before and they will make you itch just as bad as fiberglass.
Actually, the bubble mylar sounded good for the door, but I was considering Roxul for the walls.
When I looked at the different ways to insulate garage doors, I thought that if I used solid foam, I would use two pieces, slide in the bottom half, then the top, and glue them together.
So, regardless of the product, pants, long sleeves, and shower afterward?
