The reason the car was $550 was because it had a blown Headgasket. Good thing I'm a mechanic and I can do the job for under $200 with new waterpump full gasket set shaved head (higher compression=better MPG) and timing belt . When I get it running I'm going to do a zero MPG witch means what I get with the car with out mods just good driving and proper maintenance. Then I will start with the mods and add ones I have a list that I want to do
I will post MPG gains
Warm air intake
Synthetic motor oil
full Belly pan
Drag wing on trunk
Wing off window (forgot the name camback?)
Grill block top and bottom
Raised Hood
Pre mud flaps (forgot name)
Any thing else that you guys have found that helps out
Also Im going to see how much MPG I gain from tricks like acetone .
And what MPG I get from gas after I take the MPG robbing ethonal out. Easy to do.
