I dont know of a single application which puts the return line ahead of mass air sensor nor the throttle plate. The concern of oil being ingested was a great concern of ours as well but we've found that by having a cleaner thicker uncontaminated oil base, you wind up with an extraordinary lessoning of the oil being converted into a vapor.
I'm sorry but i should have mentioned that the Dynovalves benefits are seen immediately with a fresh oil change. It will still clearly work, but it takes time to recover what it can from the contaminated oil when it does vaporize.
