Old 07-11-2013, 04:34 AM   #17 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
The difference between EOC and warming it up coming down will be pretty insignificant compared to the high burn going up. By your description of low speed limit, high grade and lots of turns means that some sort of braking will be necessary, likely best to let that braking action warm the engine, power your steering and brakes rather than heat your pads and disks. Good call.
Is there any way you can go just a bit faster to keep it in a higher gear for a greater % of the trip up (perhaps dropping to 3rd for a little boost then DWL in 4th where you can) or is it steep enough that it just won't pull it?
I am not sure what type of instrumentation you have but watch your open and closed loop indicator, when loaded like that it is pretty easy to drop into open loop.
OOOh take advantage of up slope winds by having a kite boarder in the bed of your truck help you up the hill.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
