Old 07-11-2013, 10:18 AM   #161 (permalink)
oil pan 4
The generator would be run at peak efficiency at all times, and be less complicated/expensive/dangerous than a pusher parallel hybrid.
If you going to use a pusher trailer with auto transmission enough to justify its efficiency over the gen trailer then you might as well just keep the liquid fuel powered car.
Originally Posted by P-hack View Post
I did the math, 10kw @60mph? really? The pusher above gets 25-30mpg on b100 for reference, but it is an auto and lotsa weight in batteries and trailer
Sure why not?
The 10kw coming off the trailer could supply say 80% or 90% of the power to drive the vehicle.
Or god forbid, slow down to 55mph.
