Old 07-11-2013, 01:48 PM   #17 (permalink)
oil pan 4
Originally Posted by GreenHornet View Post
Here is a good article that talks about it more in depth = Diesel used as gasoline 'spark plug' improves economy and emissions
GH
"Because it’s less reactive and won’t burn so easily, gasoline could normally never fuel a diesel engine. However, the fuel-injected diesel becomes a kind of liquid spark plug, providing a kick-start for ignition. The fuel mix varies depending on circumstance: a heavily-laden truck might require a mix as high as 85% gasoline to 15% diesel, while a light load would require a roughly 50-50 blend. Fast-response fuel blending, in which an engine's fuel injection is programmed to produce the optimal gasoline-diesel mix based on real-time operating conditions, determines the correct mix."
Its called Diesel intake fumigation.
Yeah 1930s technology. The fumigation controls are the only thing new.
