Old 07-12-2013, 02:08 AM   #6 (permalink)
gil
gil's Avatar
The Drift - '85 Toyota Corolla GTS
90 day: 28.26 mpg (US)
!Rally - '02 Subaru Impreza WRX
90 day: 27.68 mpg (US)
Cinnamon - '13 Honda PCX 150
90 day: 75.86 mpg (US)
Really 14 psi max oil pressure, thats much lower than I expected. I understood that only ball bearing turbos needed low oil pressure. What is the lowest oil pressure the turbo sees?
At one point I was planing on turbo charging my Honda Helix scooter, but the oil pressure was ZERO when warm and at 6k rpm. I think it didn't require high oil pressure because of the Ball bearing crank and ball bearing cam. On my current bike, Yamaha XV-250, I expect to see 40psi max on one of the lines going to the camshaft that i can tap.
Thanks for the insight.
GIl
