Old 07-12-2013, 07:47 PM   #17 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Originally Posted by theCase View Post
  • Pump up the tires to 40 PSI.
  • Place a corroplast air dam behind the upper grill piece along with a piece of corroplast to act as an air dam under front of the car.
  • Run a length of 3" flexi-vent pipe to act as a WAI drawing air directly behind the radiator.
  • Insulate the engine, I've got a piece of cardboard over the top of the engine to help retain heat/reduce warmup year round.
  • Block off the radiator to the point that water temps run around 195 degrees. This needs to be adjusted periodically.
  • Drive speed limit.
I have an 2010 a/t (wifes) that I drove my normal route (325mi) for almost a year. I had it up from 34mpg to 49mpg for that trip.
I can confirm:
  • higher psi (45psi is better)
  • Lower grill block
  • keep engine at/under 2000rpm (52mph in this car, ever 2mph over = 1 mpg lower).
  • Wai doesn't work if you have a mass air. My mpg went down slightly and the car was gutless. It also kicked down more (prob why it lost mpg).
Additionally, ethanol free gas gave me 3 mpg alone.
-Aaron
Shooting for 600 miles of range at 65-70 mph out of a vx.
