Originally Posted by RH77
I had a similar set on my Integra -- big scoops. I found when I took off the rear flaps, it left a big hole from the wheel-well back to the bumper (which looked worse, aerodyamically). On the non-muffler side, I placed a pan to direct the air under the bumper. The muffler side was a bit more challenging -- a combination of bending the heat shield and other parts helped with the flow.
Every little bit helps!
RH77
Have any pics that you could share.
