Thank you!
I did some test previously and 3 hours seems to be perfect for me. after three hours, the heat hits a plateau, and doesn't get very higher even with 1 or 2 hour more. On the ScanGauge before starting the car and after being plugged for 3 hours, my c°WT (Water (coolant) Temperature in Celsius) shows between 47°C and 69°C depending on outside temperature and numerous other little factors. It lowers 4-5°C when I start the engine. 71°C is the highest I've seen after plugging for 4 hours and 15 minutes and it was around ~29°C outside.
It is a coolant block heater. I plan on buying an oil pan heater and a transmission heater before cold temp arrives.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
