Old 07-14-2013, 04:33 AM   #2 (permalink)
RedDevil
90 day: 57.12 mpg (US)
This is normal behavior for a relatively heavy car with a small engine and a CVT of any kind.
You have reached the point where all its power is needed.
At first the hybrid battery will aid, but its resource is not unlimited and will deplete quickly going uphill. From there the ICE is on its own.
A conventional auto would kick down once or twice and run out of revs at some point. A manual would force you to shift down.
The good thing about the CVT is that it will use all the power the engine can provide no matter what speed you go. If the speed drops when the grade gets too steep, the revs remain optimal while the gear ratio matches the speed and the force on the wheels rises, until that matches the steeper grade.
Every once in a while in the mountains you'll have situations where you cannot maintain or get to the speed you'd like, but that is the price you pay for having a car that gets great FE in luxury and safety.
Just keep your foot down. You will get there even if it takes a few seconds extra.
