Just thinking out loud here. What if you incorporated the cruise control switch? You could set the interruption switch (resume/set) to only work if the cruise control is off. This may not work on every car, but would definitely work on old Hondas with a simple relay. I'm thinking the coasting button is not used much when cruise control is being used.
