There may be a vapor reservoir you fill when you run the fuel up to the neck, very similar to my VW. With the valve disabled (a diesel doesn't need a vapor reservoir, there is no vapor), I can squeeze in a gallon more. And yes the gauge is calibrated to the level of the tank, so it will not move until the level drops.
I'm not coasting, I'm shifting slowly.
