Old 07-16-2013, 08:28 PM   #25 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Testing my updated code revealed that rather interesting fuel consumption runaway bug that was first documented in this post by DCB. It is always interesting to see my tank fuel economy just drop from 23.6 MPG to 1.0 MPG.
Re-examined the code and did some more searching around this sub-forum, and theorized that when my car goes into DFCO, it shuts off the fuel injectors, but it still sends little pulses, like in this post by rmccomiskie. I can reliably see the above fuel consumption runaway happen on every commute so far. Hopefully, tonight, when I load in this code, it will squash this bug.
Code:
ISR(INT0_vect) { // fuel injector open event handler
	injOpenStart = timer2_overflow_count | TCNT2; // calculate current cycle count
	// if timer overflow condition occurred, recalculate current cycle count and fold in overflow
	if (TIFR2 & 0b00000001) injOpenStart = (timer2_overflow_count + 256) | TCNT2;
	dirty |= dirtyInjTick; // tell close event handler that fuel injector has in fact opened
ISR(INT1_vect) { // fuel injector close event handler
	injOpenStop = timer2_overflow_count | TCNT2; // calculate current cycle count
	if (TIFR2 & 0b00000001) injOpenStop = (timer2_overflow_count + 256) | TCNT2;
	if (dirty & dirtyInjTick) { // must have read in a injector start event first
		// calculate fuel injector pulse length
		if (injOpenStop < injOpenStart) cycleLength = 4294967295ul - injOpenStop + injOpenStart + 1;
		else cycleLength = injOpenStop - injOpenStart;
		if (cycleLength > injSettleCycles) { // if the pulse length is greater than the settle time, it's valid
			cycleTemp = injOpenCycles[1] + cycleLength - injSettleCycles; // add to injector cycle accumulator
			if (injOpenCycles[1] > cycleTemp) injOpenCycles[0]++; // handle any possible overflow
			injOpenCycles[1] = cycleTemp;
			injPulseCount++; // update pulse count
			timerStatus |= timerWakeUp; // tell timer to wake up main program
			dirty |= dirtyInj; // signal that a valid fuel injector pulse has just been read
		dirty &= ~dirtyInjTick; // ignore any more close events until another open event is received
Astute readers will be able to make out the remnants of functions microSeconds() and elapsedMicroseconds().
The Following User Says Thank You to t vago For This Useful Post:
nickdigger (07-20-2013)
