Thread: i2c LCD
Old 07-17-2013, 07:42 AM   #5 (permalink)
dewasha
IIC/I2C/TWI/SPI Serial Interface Board Module Port For Arduino 1602 LCD Display
LiquidCrystal_I2C1602V1
Description :
This is another great IIC/I2C/TWI/SPI Serial Interface. As the pin resources of Arduino controller is limited, your project may be not able to use normal LCD shield after connected with a certain quantity of sensors or SD card. However, with this I2C interface module, you will be able to realize data display via only 2 wires. If you already has I2C devices in your project, this LCD module actually cost no more resources at all. It is fantastic for Arduino based project.
Specification:
I2C Address: 0x27
Supply voltage: 5V
the backlight and contrast is adjusted by potentiometer
Come with 2 IIC interface, which can be connected by Dupont Line or IIC dedicated cable
Compatible for 1602 LCD
