Old 07-17-2013, 05:32 PM   #1 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Post your "Failure Stories" and lessons learned from unsuccessful modifications
I wonder if ecomodder would benefit from an "Unsuccessful Stories" or "Less Successful Stories" forum to combat the effects of publication bias. In particular I'm thinking about A-B-A tests like the smooth wheel cover wiki - Smooth wheel covers - EcoModder.... we know that there should be a lot of variability in the results depending on the stock wheel covers...
Separately, the "what-not-to-do" lessons in materials are often quite valuable: i.e.:
  • Don't violate 15° approach angle with rigid fixed air dam materials.
  • Don't use dark-painted coroplast if dimensional stability matters.
  • Don't leave tape gum on the car in the sun.
  • Don't use polyester resin over foam.
There are some other areas where encouragement of failure reporting may be helpful:
  • Adverse effects of over-inflation.
  • Over-heating resulting from grille over-blocking.
  • Unintentionally poor visibility resulting from poor mod design.
  • Mods that failed local safety inspection requirements.
Is it a good idea, or unnecessary?
The Following 2 Users Say Thank You to christofoo For This Useful Post:
101Volts (08-14-2013), Cd (07-18-2013)
