Justme1969, yes the vehicle is still emissions legal and yes I did cover up the catalytic converter. I need to correct that. I can’t think of a good way to cut cooling holes in the .060 aluminum without removing the pan given the danger of cutting the exhaust when trying to cut the aluminum, so I will need to dismount the center pan, cut some cooling holes, and put it back. I will try to make that a project this weekend.
Elhigh, good tip on the exhaust wrap near the tank, I will look into that. I think a combination of wrap and openings for cooling will be the best benefit.
