Originally Posted by California98Civic
No extra pedal take up that I have noticed, but I was not paying attention. They're ridiculously easy to install. But even easy is too hard if they're not effective. And I just can't know for certain. Seems logical that they benefit at some level.
Are these the clips that suppose to push the brake pads away from the rotor?
They may help at some point if you put some grease at the caliper guides and at the end of the brake pads but if the caliper piston is stuck they are worthless unless you replace the calipers.
